14 BFF, 4.56 gears, Disc Brakes
longbedder
3/4 ton status
Staff member
Moderator
Ridgecrest, CA
14 Full Floater, 4.56 Open Gears
  • Brand New Timken Bearings and Seals
  • Brand New 3/4-ton disc rotors
  • Dunks Performance Caliper Brackets - these are NICE one-piece units
  • Sandblasted clean, but has light surface rust from sitting for 1 year
  • Gears are in great shape, new pinion seal, nut, and crush sleeve
  • Perches and shock mounts have been removed and the tubes ground smooth
SOLD - located in Ridgecrest, CA
Bump.
Make me an offer. You get a fresh offroad-geared 1-ton axle that doesn't need a thing but some calipers and a locker. I gotta start cleaning out my garage before I move this spring.
Yes, it's an open diff.
That may seem expensive at the outset, as you can get a used 14BFF for $100, but look at what's been done to it already. It's a fresh axle with discs - just add a Detroit and you've got a 1-ton axle ready to go for well under $1000.
