i picked up a 14bff from a 76 k20 suburban it originally had 4.10 gears but i bought a used set of 4.56 from a place called ring & pinion locally. i decided to get the crush sleeve and pinion rebuilt from six states. all bearings and races are brand new.
after installing everything following pirates write up i tried setting zero backlash by Loosening the right-side adjusting nut and tighten the left-side adjusting nut until the ring gear contacts the pinion without binding but i cant ever get to that. no matter how much i tighten the left side it never gets to were i think it should be
could this mean my ring and pinion are to worn and no good?
i have read several times about the split but didnt ring any bells untill you said something. and this must be what it is, thanks for clearing this up for me. glad i didnt completely waste my money.
