14 BFF spring plates
ok i got a question, can you reuse the plates from a 12 bolt rear axle or are they too small?
And how much you want for your set? I have u bolts so i need the plate that goes on top of the springs.
yes you can but the ubolts will need to be squeazed closed uptop to fit in the plate. have seen some guys slot the stock holes also to help with the leg fitment problem.
but propor ubolt setup is legs of ubolts 90* of tube stright up/down no veriations.
so best to just get the right plates. check there price and send me a pm with your offer shipped.
I have a set of alluminum ones, they came with the rear i bought, but eneded up using something else. 50.00 shipped, i can get you pics if you want
I decided to just mill out the ones i have guys. Thanks for the offers, if this doesnt work out ill let you know.
