14 Bff ?
R
RIPPEDK5
Guest
anyone know where i can get a mini spool or full spool for a 14BFF rear end that doesnt cost $300-$400?
i thought about that but clearly the proper way to do it permanetely is to spool it....
See id like to vear away from welding becuase if the welding isnt done properly then you have a ball of useless metal and it cant be undone.
Not to mention that a spool is compareably stronger since is a single peice. and is serviceable, along with repaireable--noting that it doesnt use the diff housing or spider gears anymore making it also lighter...
I bought a mini spool from Reider Racing for $125...along with gears and the install kit. I haven't installed any of it yet, but the mini spool looks to be decent quality. Of course the real test will be once it's installed.
http://www.reiderracing.com
It's shown on the home page....lower right
I'm not a big fan of welding a diff either, so this is the way I choose to go.
