I know most run disc brakes but can someone tell me what the torqe is for the 4 bolts on the backing plate is?
thanks, Ed
thanks, Ed
yes, i couldnt find that info,
thanks,
Ed
Seriously, this is going to be a standard bolt torque by size, since it's just 2 flanges being bolted together. You can look it up here after you figure out what size it is:
http://www.engineershandbook.com/Tables/torque.htm
The bolts in question are 1/2" fine thread which the torque isn't listed on that chart. Regardless, those bolts aren't in any kind of load situation.
Hmm, selecting the fine thread page on that site, it's 81-103 ft-lb. If you're not going to use the proper torque, don't get the torque wrench out at all.
http://www.engineershandbook.com/Tables/torque2.htm
And grade 5 is fine when it's 4 bolts holding a backing plate, but 50 ft-lb is still below spec, and any slop will allow the plate to twist and hog out the holes. Would you really want those bolts to come loose? It's not something you'll see easily when inspecting your truck either. Maybe 50 is "close enough", but that's not what he asked. Scott, I don't understand why you would throw out a random guess to answer a question like that. I guess we just disagree on what constitutes help.![]()
Are you trying to imply that there is a given torque value of 50 ft/lb for these? I'm used to torquing spindle nuts on tapered roller bearings at 50 ft/lb (NO, not on pickups), so I consider that a very light torque.You do realize that the heading says...
[FONT=Arial, Helvetica, sans-serif]SUGGESTED TORQUE VALUES AND CLAMP LOADS [/FONT]
[FONT=Arial, Helvetica, sans-serif]GRADES 2, 5, & 8 CAP SCREWS[/FONT]
When there isn't a given torque value for a particular application THEN you can use the SUGGESTED torque value based on bolt diameter and thread pitch.
I gave him "my help" which no one else seemed to want to do. I build engines for a living and i undertsand the importance of torque values and in this case 50 ft/lbs is suffiecent.
I also replace anything I find on my truck that is grade 5 with a grade 8, unless it's a specialty fastener. I think we agreed on something once, maybe it'll happen again some time.
Are you trying to imply that there is a given torque value of 50 ft/lb for these? I'm used to torquing spindle nuts on tapered roller bearings at 50 ft/lb (NO, not on pickups), so I consider that a very light torque.I also replace anything I find on my truck that is grade 5 with a grade 8, unless it's a specialty fastener. I think we agreed on something once, maybe it'll happen again some time.
