I need to pull the seal housing off and I cannot locate any gear puller that will work.
The bottom of the pressed on bearing is below the ridge of the seal.
The normal clamshell pulleys I used to pull the D60 and other side of the carrier can’t be used because of the copper air line, aside from the fact they don’t fit the seal body.
What are you using, how do I get this bearing off?
