would it make much of a diffrence to run one in a truck with it being wider, would it look wierd or just look like i have wide wheels and how much wider r they
nevermind the vans are suppose to be 70'' from wheel mounting surface to wheel surface and the truck ones r just 67'' so it wont make to much of a diffrence or i could jst get diffrent back spacing on my wheels
c&c = cab and chassie like flatbed or box truck vary narrow. try bleading brakes the springs are so close.
perch = spring mounting pad
and i have a van rear and its 70" wide the dana 60 srw is 69" wide.
the widest rear is a drw non c&c dana 70hd then swap on srw hubs this brings it out even more. then use a drw dana 60 front . this whole setup lets you run h1 non recentered rims and same trac width basicly.
