SchnorrCS
So I'm doing the 14 bolt swap, and I had some flex lines made to go all the way from the caliper to the "T". anyone see a problem with routing them over the tops of the springs rather than under? Was thinking it shouldn't matter, as long as they are hooked to the axle tube. I was gonna use zip ties until I can come up with a better idea. Any thoughts?
cS
cS
