Also a question for Virgilh, when servicing a 14 bolt do you normally take the carrier out?[/quote]
no but regular oil changes (servicing) will keep this from happening being a differental guy i change my diff fluids after 7500 miles or bi weekly when im taking the boat out. that is caused by lack of proper lube on them and when you park the spider gear sticks to the crossshaft when you take off again it gulls the cross shaft untill it finally breaks the shaft, you wouldnt feel it when your driving because you have 2 other spider gears hold it in place when those fail you will feel it
