14 bolt corp fitment
blazd88
Lubbock, Tx
i have found a 1 ton 14 rear but it is a dually. i was wondering how much i would have to change to make it single wheel and what else would be involed in putting under my K5 /forums/images/graemlins/dunno.gif
If it's a 14 bolt from a dually pickup I'd verify the width because if it's from a cab and chassis truck it isn't even gonna be close.
What did it come from?
You can make a dually front or rear end a single wheel front or rear end by using the single wheel hubs and rotors on the front or the single wheel hubs and drums on the rear. When switching from a dually to single wheel on the rear I think it works out better and easier to put disks on instead of the drums. The axle housings are almost exactly the same only two differences that I know of: 1 spring perch width on all 1 tons was different that 1/2 and 3/4 tons. 2 I think that the break backing plates are in different locations fro dually to single wheel.
The fronts are real easy. The rears do require quite a bit of work to make them mount to any thing but a 1 ton frame.
