14 bolt disc brake conversion problem
Jspohr
Registered Member
Owens Cross Roads, AL
So I have 2 vehicles with 14 bolts with drums (94 sub and 99 sub). These are both FF. They have outboard drums, meaning the drums just slip off without having to remove the hub. My problem is, I cannot find a disc brake conversion kit, or even a bracket for this type setup. All the ones I've found are for the set up where the drum is behind the hub. Anyone know where I can at least get a bracket for this..... Kit would be better. Thanks.
Of course. I was just coming back to say I found it at the same place. I've spent probably 3 days searching off and on and Murphy's law says that I would find it as soon as I write a post about it.... Oh well, maybe this will help someone else down the road.
thanks.
I haven't used one of his kits however I've heard good things about them.
