aj's tonka truck
Registered Member
- Joined
- Jun 29, 2004
- Posts
- 53
- Reaction score
- 0
I am installing a 3/4 ton 14 ff rear diff disc brake converted axle into my 91 k5 blazer. I want to run aluminum wheels so I think the stock wheel studs will be to short. What is the correct wheel stud, part # and length that I should use. The stock ones are just 3" long. I looked at the DOR-610-301 which are 3 1/4 in long but the part store said they show this to be a Ford wheel stud at 3 1/4 length x 9/16 thread. Is this the same thread as my GM dana 60 front diff studs? Also the heads on the dor-610-301 are smaller dia. than the stock ones. Any help would be great.
