garydan
While this site has a lot of information, sometimes there are also many answers to the same questions. So I guess I'm asking for confirmation, or just another answer
I've reattached the hubs. If you know, please confirm I did this right.
1) PLace hub on spindle
2) Put flat washer in
3) Put inner spindle nut on, torque to 50ft-lbs while spinning the hub, back off then torque to 35ft-lbs.
4) Place key ring (or whatever its called... with the bendable tabs)
5) Put on outer spindle nut and torque to 65ft-lbs.
6) Bend a tab into the indent on the outer spindle nut (I was only able to fit one... which is how it was when I took it off)
Did I do this correct? Here is the end result
Full Size Pic: http://garydan.no-ip.info:8080/k5blazer/DSC07266.JPG
The next question I have is that I noticed one of the new seals I placed doesn't seem perfectly flush, when I spin the hub I can notice the seal moving in an out. It's very subtle. I took the hub off and tapped the side that I thought was protruding but its still not perfectly even. Should I go get a new seal and start over or not worry about it? The other end is perfect.
My next question concerns the "Chevette" flexible brake lines. I've seen some say they are perfect and others say they aren't long enough. Should I go with the Chevette lines, or get some braided steel lines instead?
Thank you for the help,
Gary
My progress so far....
Before
After
Gary
Before
After
when i pulled the hubs off the junkyard 14bff there was just one spindle nut. maybe they were already taken by someone else, i still gotta pull my D70 hubs.
