14 bolt FF - 2wd/4wd
Vee
Lancaster, CA
what are the differences between 14 bolts from 2wd rigs than ones from 4wd rigs? I've heard that the shock mounts are lower about an inch. is that all?
i am using a 2wd rear diff on mine, i didn't know about the shock mount issue whan i got it, but ran it for awhile, and did eventually bed one up pretty good and ended up having to cut it off, rebuild it and weld it back on,,,which was rewelded up alittle higher this time.
still haven't done the passenger side though...maybe soon when it gets rebuilt and an actual locker installed in it. :D
the stock shock mounts will work, you may have to work at the driverside alittle to get it to fit, or mount the shock upside down, some people don't like that idea though.
