They never offered the 14 bolt FF axle from the factory in a K5 Blazer, so if you calling around and asking for that axle for that vehicle then most places will tell you it doesn't exist. As stated above, the 14 bolt FF axle came in 3/4 ton (C20, K20) and 1 ton (C30, K30) trucks and Suburbans in both 2wd and 4wd. I haven't been in the market for one of these axles for a long time but 10-15 years ago all of the local junkyards sold them for $100 and could have bought an entire trailer load of them.
A few notes:
- 3/4 ton versions ('87 older pickups) would have the correct spring pad spacing for a K5
- many 3/4 tons had the smaller 9.5" semifloat 14 bolt.........this actually is a decent axle to replace a 10-bolt if you are not running huge tires or beating on it off-road alot
- 1 ton versions would need the spring pads moved
- All of the 14 bolt FF axles, and most of the 9.5" semifloat axles, used 8 lug wheels as opposed to the 6 lug wheels found stock on a K5
- there were 9.5" axles with 6 -lug bolt patterns, but not in the older trucks, so some additional modifications need performed
While most people will say a 14FF is a "bolt in" swap for a K5, it really is not a true bolt in affair. I think it's a pretty simply swap for somebody with experience, but does requires some parts other than just the axle. Assuming you have a 3/4 ton version with the proper spring pad spacing, you need u-bolts and spring plates, you have to deal with the u-joint (conversion u-joint or modify the driveshaft), and deal with the 8 lug rims....at minimum.
