Smitty
I searched for this, but wasn't able to find what I wanted. Hopefully someone can help me out...
I have a 3/4 ton 14BFF with 3.73 gears in my '56 that I want to swap with my CUCV that has a 14BFF with 4.56 gears. I know about relocating the spring perches, but I'm not too sure about the brakes.
I have disc brakes installed on the 3/4 ton and the stock brakes on the CUCV. Will the backing plates and brake assemblies swap directly from one housing to the other without any modifications?
. That did not even cross my mind. I would recommend and gear swap also it should only take a couple of hours. Alot less time than removing and rewelding perches and swapping your disc brakes out and rebleeding they system.
