14 bolt FF hubs with disc brakes studs
As long as your 14ff had the 13" drums then you will re-use the original studs. One thing that i've found out though is that some (most) of the 3/4 ton rotors the machined area for the stud head to sit in is too small and the best method is to machine the head of the stud so it is 1" in diameter. Doing this will allow you to never have to deal with it again. The other option is the machine the stud recess in the rotor larger but then if you ever need another rotor you may have to do it again to the new rotor.
