14 Bolt Help, Quick
79Stomper
Forest, VA
All right just got home, pulled the 14 bolt out of the back of the Cherokee. I need to I.D. The gear ratio.
This is stamped on the ring 3 GM 464917 12 45 3 81
Is there the gear ratio anywhere in here? /forums/images/graemlins/confused.gif This is my first 14 bolt so would like to know if I need to start counting teeth yet.
Also there was a metal shaving in it. Seemed to be like a shim of some sort. it was stuck to the bottom in a pile of sludge. Don't think the rear was ever PM'd.
TIA /forums/images/graemlins/thumb.gif
i usually just count teeth, but it looks like there could be 45 on the ring gear,and 12 on the pinion, giving you 3.75...or ~3.73
Thanks, I see it now. I just couldn't figure out which numbers it was but now I see. Done it no probelm a few weeks ago with a Dana 60 but this one stumped me. I am a simple minded person and there were simply too many numbers.
Thanks
James
