I got new Timken seals for my 14bff hub. It's not obvious to me which way they should go in. I can take pics if needed, but from one side you can see the spring inside the seal. I assume that goes to the inside of the hub?
Sounds good, thanks. By the way, anyone know where to source axle flange bolts? I know I can use regular grade 8, but I'm missing one and would like them to match.
If you have not already bought the seals now is a great time for a 2 piece seal. you will get a new seal surface and seal they come as a kit. a little more money but worth the extra cost. I have used them a lot on questionable where surface never had a leak.
Interesting. Do you have a part number, or something to search on?
