14-bolt on craigslist
bit high on $
and move perches / shock mounts to fit older frame specs.
plus some srw staring in 90's then most all srw went pop off drum brakes . these take totaly diffrent disk brake stuff . and can not be swaped to older stuff as the spindle is diffrent.
Good info on the brakes. I definitely want to be able to use a standard off the shelf conversion kit.
too bad your in AZ, I have the older 14 bolt with 3/4 ton perches that fit the blazer w/ 4.10's, open diff for sale for 125.00 but shipping would kill it...
easy way to spot the brakes is
rim off axle
drum on front side of hub = pop off
drum on back side of hub = old style.
i found this out the hard way few years ago. :doah:
yep slide on/off drums give it away, the ribbing on the pumpkin also gives it away...
