Stomis
Professional Amateur
Went to install my locker and found it in the bottom of my differential. I ordered a new one and am really hoping that I dont need to remove the pinion to install this. Does anyone have experience with replacing these?
Its been a few years since I fully rebuilt a 14 bolt but I don't remember there being any washer or anything there BUT...
I remember when the 5.38 gears for the 14 bolt first came out that there was a huge thread on pirate complaining about the way they were cut, part of the end of the pinion got cut slightly (unintentionally) during the gear cutting process. The gear suppliers solution was to supply shims to move the pinion support bearing onto the good surface, which means there is some kind of snap ring or something that determines the depth of that bearing.
Luckily for you, however, the 14 bolt has a removable pinion support so you won't need to mess with re-shimming anything. Drop the driveshaft and remove the 6 pinion support bolts. Remove the pinion support and DON'T LOSE OR BEND ANY OF THE SHIMS that will be between the housing and pinion support. The whole pinion and everything will come out. Reassembly is the opposite of disassembly, just make sure everything is REALLY clean.
AFAIK the 14 bolt and 9" are the only two that have removable pinion supports and allow you to remove the pinion without messing with pinion bearing preload.
Yeah I am damn glad of this, seeing as how I have no rearend setup experience.
So does that mean there will be a snap ring for my 14bolt, with 3.73's or only on those aftermarket gears?
So no serrated retaining washer found?
I have used mustard in a pinch.....worked greatlithium grease - just pulled where the contact was instead of marking
white out - dried too fast
wax - didnt work
spray paint - dried to fast
I have used mustard in a pinch.....worked great![]()
I forgot what its like to drive with a locked rear... been a while.
