hunter29078
If I convert my rear drum to a disk using the plates from diy4x will I still have an emergency brake?? What will I need to do to fab one?? Thanks
3. a bit more complicated, and what im going to look at tomorrow, is grabbing disk brakes off of a newer style 14bff axle, and seeing if they can be grafted onto a drum brake axle. in my case, a D70HD. Newer style brakes use whats called a Drum In Hat (DIH) rotor, with a non parking brake caliper on the rotor, and a drum style brake for the parking brake built into the rotors center, which is cable operated.
4. Line lock - using the line lock for a parking brake instead of burnouts. some claim they will hold for weeks on end, others have voiced concern about bleeding down pressure, or more to the point voiding the reason for a parking break. AKA if your hydrolics fail, you have no backup cable operated system.
This is what I don't get about the line lock. Maybe it is just that I use and park my truck different than most.
Even when i had my drummed 12bolt with ebrake I still used a 4x6 wood block when my blazer is parked on the level garage floor. Extra security when the kids are playing in the garage or in the driveway and the shifter accidentially gets knocked into neutral.
Now that I have the 14 bolt with no ebrake I still use the wood block at home and when running around town. My question is how long and often do people actually need to have a line lock set to allow it to bleed down? Why not use a block of wood or something if the truck is going to sit for more than several days? If your truck is broken down on the trail on a hill you are going to get the rig fixed pretty quick, right? If you have a sloped driveway wouldn't you put some other sort of parking stop, wood block or something else under the tires.
Maybe I don't fully understand the workings of a line lock but it seems like the bleed down affect is overstated and exaggerated.
so sorry guys, someone else is gonna have to pioneer fitting the full float disk brakes to the drum style axles.
