Its finally time. I have a 14 bolt 6 lug semi float rear end out of a 1992 Z71. I just sand blasted it and primed it. I need to order the spring mounts and shock mounts to have welded on. But I need to know what carrier to use. Keep in mind it’s going in my 1986 K5 with a built 5.3 LS and a built 4L60. I have 33 inch tires and I plan on using 3.73 gears. I will rehear the front as well. But my question is what limited slip type carrier should I use. Obviously I will need all bearings seals and related stuff. Is there a company who sells all this stuff and has any one had experience with them. The current carrier is an open style. Oh and finally I am NOT doing any heavy wheeling or towing. Thanks.
