ChefBear
Alright, here's what I think I need to do.
I got spring perches of of the 14 bolt. Prep the surface and then with everything bolted up under the truck, adjust the pinion angle to mirror the yoke of the transfercase. So that the universals on each end of the drive shaft are running the same angle.
Then I weld the spring plates in place.
Yes / No Any corrections or changes?
