I have looked everywhere. Cheapest I found was a stock 8 lug for $150. Not to many semi float axles around me. I haven’t checked any junk yards.For $500 he should load it for you while his wife makes you lunch.
Any suggestions?Geared right and hopefully the LSD isn’t trashed, brakes
Any suggestions?
Take the diff cover off? I will probably put disc brakes on it. Not to worried about the brakes.
I have new brakes going on the front. Full rebuild. Ball joints and much more. I have been looking into the front wheel stud situation. Will have to figure something out. Found a few post with good info
I just installed a set in my 89 V1500, I can get you the part number later.What did you use on the front? Just left the stock 7/16"?
Last I knew Dorman had discontinued the front 1/2" studs that were IMO a bit short, but designed the same as the stock 7/16. Never could find anything else that had the knurling as GM had done in the front in 1/2" unfortunately.
They looked close enough side by side with the old ones for me. The knurl still has more than 50% engagement in the bearing hub flange. I do not expect any issues for a road driven daily. I would think more about it for something you use hard offroad, like going with 3/4 ton axles.What did you think of them as-installed? I actually revisited all the posts from before and those had come up, but I think it may have been the smaller head, slightly undersize knurling, and potential thread/knurl interference that kept me from trying them based on specs alone.
Your pics don't appear to show any protrusion of the knurl, so I'm thinking you had no reservations installing them?
With the ones I used discontinued, these are the only 1/2" option left I'm aware of that come close.
Still driving back. No offense taking. No man should whine period.If you drive 6hr round trip and do NOT pull the cover dont come whining here you got screwed . .
I pull them even if 2min drive . I dont trust ANYONE .
Not being rude . Just 46 years old and seen way to many so called / bad sellers / scammers . . Just trying to save you is all .
To everyone replacing the front studs with 1/2 inch? What/why?
If the rear are now going to be 14mm on the 9.5… would you not want to source 14mm studs for the front so that all wheels, lug nuts, and studs match on all 4 corners?
Is the auburn axle 8 lug?I have been looking for new axles to go to 6 lug.
I found some for 88-98 I believe but they are shorter. I also found some from a Tahoe 2007 or 2010+ that’s real close to stock length.
6 lug 33 spline.
Let me dig info up
YesIs the auburn axle 8 lug?
88-98 2wd = narrow . 4wd = wider . From what i have read and seen a few .I have been looking for new axles to go to 6 lug.
6 lug 33 spline.
Let me dig info up
I was just looking through. I remember someone adding 1/2” spacers to the outside. Remember that thread?88-98 2wd = narrow . 4wd = wider . From what i have read and seen a few .
Read through this
