14 Bolt SF
olanchamedic
Fort Mohave, AZ
Looking for a 14 bolt SF 8 lug rear axle out of an 88 to 98 4x4 truck. Hopefully in So Cal or somewhere close to the High Desert in Cali. Dont care what gears. Let me know what you have. Thanks
Steve
ssuming you mean NBS truck with wider pad spacing?
cause I have one from an 88 sub, but that won't do it for you right?
I'll keep an eye out at the local junkyards O. Do they look just like my 14bff except flat on the ends SF?
Kinda, cover is a 14 bolt, but shaped different. 8 lug axles. Has to be out of a 4x4 truck cause they are wider than the 2x trucks. Thanks Brent
oh yeah, and Pick Your Part is 50% off Sept 1-3rd. I got my D60 from the Bakersfield lot, maybe you can get lucky too. Ask Jeff if he's going through the lot on that weekend, most likely will be, then at least you'll know it's there and go from there. There :)
