Hey everyone I am swapping my truck from dually to single rear wheel. It has the Cab and chassie rear in it with the regular 1 ton spring perch measurments, 40.5 inches. I was just going to try and get a 1 ton single rear from the junk yard but have not had any luck finding a 4.56 single rear wheel. I read on pirate in the 14bolt bible that you can swap the hubs from a single rear wheel on to the cab and chassie to change the width because the housings are the same other wise. Has anyone ever done this? I am a bit confused as to what to do about the brakes. Do you have to weld on a new backing plate flange or use a spacer or some thing to change the width of the backing plate to match up with the single wheel hubs? Any and all info on this would be really great. Thanks
