14 bolt yoke
4X4HIGH
1 ton status
Fremont, CA.
Can anyone tell me if the 14ff and the 14sf use the same yoke. My buddy is needing a new yoke for his 14sf and i have a good yoke from a 14ff i can give him if it is the same. As far as u-joint size that part is correct. This yoke is a 30 spline but i'm not sure of the 14sf splines.
i don't think they use the same yoke. i believe the ff uses a bigger pinion.
i do know that the 10 bolt uses the same yoke as the 14bsf. there were factory options for a 1350 10 bolt yoke. the only difference is the seal protector is the wrong size and will need to be removed.
Jason4x4 said:
they are the same, I sold one off my 14sf to a guy that put it on his ff.
Thanks, i thought i remembered someone doing it already.
