gmcjimmy4x4
Ive never done this one before. Just thought id see what you guys think about doing this at home? Are there any special tools needed? Or is there critical measurements that will be affected by this work?
Do you have to take the gear out, or just remove the yoke and replace the seal and crush sleeve and put the nut back on? Am i missing something?
To do it correctly you need to pull the pinion support/pinion gear out of the housing and buy a new crush sleeve and then install the new seal and set the pinion bearing preload using the new crush sleeve. Yes people have changed the seal without going through the correct procedure and have been successful but thsat doesn't make it correct and or guarantee that it will work.
thanks for the info. Im considering doing it, but then again the shop only wants $100 to do it right the first time.
i would watch them do it, make sure they dont just pull the ol switcheroo.
