1410 208 rear SLIP YOKE*sold*
85mudblazin
Austin,TX
This was a custom piece made by HAD. It is splined all the way to the end and has roughly 7" of slip. It is in like new condition. Has maybe 4-5 runs on it.
I paid $115 to my door for it.
I will get it to your door for $70.
Heres a picture of it when I first got it.
muddybuddy said:
it allows you to run a bigger u-joint. you wont break a 1410
Oh so for example my current 1/2 ton truck has a tailshaft off of my np208 for an s44 so if someone had some serious power or was paranoid they could swap tail shafts and run the big 1410 w/ a new driveshaft or conversion joint?
Are 1410's what 14ff's run?
-Avery
-Avery
1410's also give more angle as well as being much stronger.
I have broke 2 of the stock size yokes, not to mention a bunch of the s44 joints. Installed this and all problems went away:D
I'll vouch for that. Also, 85's only selling this because he upgraded to a new (and different) T-case, so he doesn't need it anymore.
TTT
Posting for Marv. He wants this, well er needs this too. Hold his spot.
