1410 yoke
burbanbeast
Collierville
ok so i got my 1410 rear yoke(14bff) today and realized i have (what i believe to have) a 1/2 ton driveshaft. am i going to have an issue installing my 1410 ujoint in? what would my best solution be?
Have your local driveline shop install a 1410 yoke end on your driveshaft. This will keep you from having to buy (if they're even available for that conversion) a conversion joint which aren't cheap.
You could always see if there is a conversion joint available. I don't like them for 2 reasons, 1st, they aren't cheap, 2nd, if you break one on a trail you're unlikely to walk into any parts store and buy one off the shelf. Most autoparts stores can "get them" but they don't usually stock them. I like to know that if i break something and need a replacement part i can walk into just about any parts store and buy it without having to order it.
If you don't already know, replacing a yoke on a 14 bolt is more than a simple remove and replace affair. Search on here if you don't know how to do it.
