14b 1-ton axle with posi
U
UofA_Blazer
Guest
I'm not sure on the gearing but it worked great when we parted the truck out. It has some kind of traction device in it that seems to work like a posi. Just looking for best reasonable offer. Located in kingman, Az
Is it a full floater, single rear wheel, what did it come out of ?
It's a FF but to be honest I don't know what it origionally came out of. It was in a dodge power wagon with a chevy drive train that my brother bought and drove for about 8 years. If you have any other questione feel free to ask....i can also take the cover off and find out the gearing if need be.
That would be cool if you could get the ratio, does it apear that the spring pads/shock mounts have been relocated? I'm needing an axle pretty quick , my '77 Jimmy just lost teeth on the rear pinion gear. I was hoping to find a bolt right in replacement.
ill try and get that done this week. I believe the shock mounts have not been moved but let me take some pics for you
The gearing is 4.10 and below is a pic of the spring perch. Let me know what you think.
gsdvt3ft8zyu
gsdvt3ft8zyu
Thanks for taking the time to get the gearing. I've bought a '74 K5 donor, it has an axle with aftermarket shafts, and bonus 4" lift.
