sixpennylizard
Registered Member
I need some opinion's and some help with the carrier on my 14bff. Today I finally got around to putting the lock-right in the rear and when I got it apart I saw that the cross was broken and had chewed into the carrier bad enough it was noticeable. It looks like it came apart inside the spider gear and was broken for a while because the other half of the shaft is kinda fused to the spider. So my question is this should I get a new carrier with the spiders and cross or find a new cross and use the old carrier? If I should replace it where can I find a new one and what do I look for in the new one? I have 4.10 gears in it now and as far as I know that is what it originally had from the factory. Other than the junk yard where can I source a new one? Thanks in advance for the help I'm pretty bumed right now I was so close to being ready to install everything and now this.
Nick
Nick
