14b FF Axle Tube Steel Type
ZombieK5
Bucks County, PA
I need to weld onto my 14-bolt axle and I am wondering if anyone knows the type of Steel the tube is made from? I understand that the center section is cast iron but are the tubes themselves mild steel? I understand that nickel wire is required to weld mild steel to the center section but I'm wondering if I can get away with basic welding wire if I'm only welding to the tube itself?
Didnt need nickle on my 14ff tube to center weld . Just good clean prep and pre & post heat and slow cool down with welding blanket .
Tubes should be reg old steel is all .
Great. Not welding center. Just a tube Truss that's part of DIY4X "Wraptor"
Then I can use regular MIG Wire that I use for other repairs. Using 75/25 gas.
I may add full welds from Tube and Center. May use Nickle wire for that.
Guy that did my tube to center welds was old school . He used stick for big heat in the joint . Dont recall # he used . But no shiny nickle color .
No need to pre heat the tubes unless you’re using a small welder with not enough heat, only the center is cast, no different than welding perches on
