mpio13
Hey fellas,
My rear 14B FF keeps leaking at the outer seal on my driver's side. I've replaced the seal a couple times now, and saw that the sealing surface on the spindle is pitted pretty badly.
I tried using some emery cloth to smooth it out a bit, and tried to get the seal to ride on the smothest area possible. No luck. Is there a way to replace that machined surface? Is there some kind of repair kit I can press onto the tube and maybe use a different diameter seal?
I'm hopefully going to get the Sky Offroad disc brackets sometime soon so I'm hoping to have a solution by then.
Thanks!
Thanks!
