14B Hub wont quit leaking
Got Smoke?
Bethpage, TN
Hey guys I'm back again. Sold my 99 tow pig, puller is in pieces being built back to a street truck. Currently my 79 K20 is the only truck I have to use/drive. This past weekend we changed the pinion seal and the pass side inner hub seal trying to get some leaks taken care of on my 79 since it's going to be driven more regularly now. I noticed when I pulled the hub off that there was a very hard build up in some spots on the spindle...kinda scratched at it with a screw driver and none came off so I installed the neal seal in hopes that it would work.
WRONG
Seal is still leaking BADLY and I'm wondering how I am going to go about fixing this. A friend told that I can get a "ready sleeve" to install on the surface where the seal rides and it will seal then? I talked to the local parts house and he said yes it will work but he needs the diameter of the spindle where this seal rides. It will be a day or two before I can tear mine back down to measure this so I thought I would ask if anybody else has encountered this and how they fixed it.
Thanks.
Yup installed a speedi sleeve yesterday and no more leak!! Spent 20 Mins under the truck with a pressure washer to get a lot of the mess cleaned up too LoL
hmm, got a part number for the 14bff speedi sleeve?
