14b sf axle code?
runninfromthelaw
New Mexico
So I have found 4 6lug 14bsf in the local scrap yard. does any one know the gear ratio for the codes stamped on the axle tubes. 1:KGU 2:KGW 1:TMM I would like to see if i could get the better ratio.
I am going to trade a 8lug 14bff out of and 05' 2500. I know the cost to make the 8lug work in my K5 plus new wheels isnt worth it.
I have seen on here that the 14sf will be a great upgrade to my trashed 10b.
So the old 10b had 3.42 what 14b would be the better choice. Since the ratio is different I will have to change the front also before to long.
I would look for one with 4:10s. IMO, I would look for both a front/rear matching set from a K20 or 3/4 burb. This will get you 2 complete axles with matched gearsets. But will also require you to get 8 lug 16" wheels...
Or, just keep looking for the elusive 6 lug 14bsf. You can find one from an 88-up IFS truck but you will have to move the spring perches and shock mounts.
My Dad's 98 Chevy has a 6 lug 14b in it. He bought the truck new in 98, so it's factory.
What's weird is the trucks combination... It's a Ext Cab Cheyenne. Power locks, Manual Windows, 4x4, and.................. 4.3L V6. Lol.
It has a heavy rear spring pack, and the 14b in it. It's also an auto trans.
What was GM thinking with that??
It was built on a Friday and they were trying to meet their quota for the weeks build numbers. I can see it now...
Alright, last one for the day.
We're outta ten bolts.
Grab that 14 bolt and spring pack from the 2500 line.
OK.
May as well put a 350 in this one.
We're outta 350s.
Get a 305 then,
Outta those too.
What's left?
4.3s.
Whatever, it'll have to do. What time is it?
4:53
Alright, almost beer o'clock! That truck done yet?
You get the idea here.
Does it have F44 in the glove box RPO code options list?
Years ago on www.off-road.com/chevy we started combining knowledge and noticed that everyone with a half ton WITH a 14SF had the F44 option code.
Some combinations of RPO's added the 6 lug 14SF. We had a few guys with heavy duty half tons with the 10 bolts and others with regular 1/2 tons with the 6 lug 14 SF. Never did figure out rhyme or reason.
OK.
We're outta 350s.
Get a 305 then,
Outta those too.
What's left?
4.3s.
4:53
LOL, that sounds about right! :haha:
Years ago on we started combining knowledge and noticed that everyone with a half ton WITH a 14SF had the F44 option code.
I'll check and see if it has the F44 code. I know it has 3.73s, and the rear end is open (no G80).
This one definitely isnt a heavy half. It doesn't have an aux trans cooler or anything.
To give it credit, it does seem to have a lot of power for only being a 4.3L. We've used it to pull a loaded car hauler, and it pulled it every bit as good as the old Z71 with a 350...
