14B SF Price.......is this a fair deal?
BurbinOR
3/4 ton status
Oregon
Have a local guy that has two SF 14 bolts.......one 6 lug and one 8 lug (didn't know then made 8 lug SF, but that's beside my point
. I am looking into the 6 lug, wanting to keep my Centerlines. I will know for sure on Sunday, but if it has 3.73 gears (like my existing 12 bolt does) and a "factory posi" (the dreaded GovLoc?) is it worth $200. Future plan would be 4.56 gears with a Detroit. I am thinking it is NOT, as it does not have brakes or backing plates. If I convert it to TSM rear disks, don't I still need the backing plates or not?
Anyway, your esteemed opinions are requested. Seems I have heard of getting these for about $150 with brakes, would have liked it to be a bolt in affair.
<font color=black>'79 - 406 TPI -<font color=orange> K5#5 - <font color=blue>See it at---&gt;http://www.blazzinor.coloradok5.com
With no brakes offer him $50-$75 for it. Don't know about the TSM kit. Messure the sring plates to make sure thay are the same. I was told the late model(92-98) axels are too narrow. The 8 lug 14sf is what I have in my 86 Sub. 3/4 ton.
blazen91
Protect the land FOR the people
<font color=red>Not FROM the people</font color=red>
I have to agree with Mike, $50-$75 is probably more than fair since you'll have to buy new brakes, drums and backing plates.
The gov-lock isn't the most desirable LSD goin' either, so basically you'd be buying a core.
I'm pretty sure the TSM kit comes with its own backing plates, so that may be the way to go.
Rene
Well, Rene, I could always ace the GovLok and drive up to BC and have you make it a Lincoln Locker!!!!!!!!!!
Bring it on up dude! At least then it'd be a LOCKER!
Rene (gettin funny looks goin' thru the drivethrough now!)
The average price around here for the 8-lug SF 14 bolt is about $250, though I have found complete assemblies for $100. The 8-lug versions were very common on 3/4 ton pickups and Subs starting back in the early or mid-80's. The 6-lug versions came out with the new body style pickups in '88 and were used in some light duty 2500 (3/4 ton) series and few assorted 1500's (1/2 tons) with the trailer towing package. This also means that you will have to move the spring pads and probably the shock mounts to bolt up a factory 6-lug 14 bolt to the older style truck, and I'm not sure about the overall width. The 8-lug could be from either the newer or older style trucks. A version from the older style should pretty much be a bolt-in.
