14b spewing oil
blazinzuk
Buzzbox voodoo
Rexburg Idaho
Well not quite but its enough to put some gear oil on the back of my tail gate and gas tank.
so what would cause this. The pinion is rotated up I assume that has something to do with it.
I don't have a breather tube (taking care of that today) will that help?
Do I need to drill another vent and t the two vents?
Its a full floater with 4.56 gears and a detroit from a military pickup
Check that you are not loosing it from some other source first. My 14ff is tilted pinion up at 7 degrees, with no problems. But if the breather is plugged or you have a bad seal or gasket, there should be some hint ot where exactly it is coming from. If not, hose it off, fill it up and try again.
is it shaved?
get your mind out of the gutter so mine can flow past!
My 14 leaks like a diaper out the bottom where the 14th both should be...
Shove the vent line back on it, see if it blows it out of that. If so, you have other problems:confused:
Let's see:
Is it shaved?
Mind...gutter...flow...bottom...
Yes, yes.....coming...
Shove.....blows...
Hmmm :thinking::whistle::thinking:
Yes, definitely check the vent lines. I don't see how one could think of anything else. :haha::rotfl::tongue1: Look for cracks :ignore: or wetness :shame:
