87BrnRsd
Something is definitely wrong. Did you reset the proportioning valve? That could be a simple solution. Also, it shouldnt increase your stopping distance switching to a 14ff, it should decrease it. The drums on the 14ff dwarf those on your old 12 bolt, So with bigger drums, how would it be possible to have a longer stopping distance if everything is working properly? Also, it shouldnt get worse if you put a 3/4 ton 10-bolt front in. Its the same situation. The 3/4ton 10 bolt has a slightly larger rotor than the 1/2 ton 10-bolt, which should mean more braking surface, which means, less stopping distance.guido666 said:I have a '79 Blazer, and just swapped out my 12b for a 14bFF in the rear. I also installed a set of 18/39.5x15 Boggers on the rear only. Now I can't stop hardly at all. I bled the brakes quite thoroughly (ran about 1/2 quart through) and still it seems to take forever to stop. I was expecting some slow stops, but this seems worse. Is this just what I should expect (and what will get worse when I put on the 3/4t 10-bolt front axle) or is something wrong?
-Harrison
