14bff--- 6lug hubs!!!!!!
crazy427
Edison , NJ
IM upgrading to 8 lug and disc.so i am selling my 6 lug stuff. I have a set of rear 14 bolt full floater hubs that have been converted to 6 lug using TONYP's 6 lug adaptor set. the hub has been machined down a couple thousands of and inch so the adaptors slide over and the center of a 6 lug rim will slide over. I also have a set of aluminum 5 star 16.5 x 10 wheels i will be selling once this is all done, the rear rims have been slightly modified to fit the conversion becuase of how thick aluminum wheels are. a set of steel wheel will fit with no problems and no mods. this is a great way to get that 14bff into your truck with out doin a full 8 lug swap. the hubs have new bearings and this set up has about 8 months of use on it and has seen speed over 80mph with no problems. pm me with interests, Joe
I am getting alot of inquires about these. I willl try to get some pics up by tommorrow.I need a set of 14bff stock hubs and some 8 lug 16.5 wheels before these can leave me becuase this truck is my dailydriver . I want $200 for the hubs drums and adaptors all assemebled and ready to go on.They can be picked up or shipped at buyers expense.The matched rims ( set of 4) i also want 200 for. It is a really trick set up and i had no problem with it.I Now i have some more money and want to upgrade to rear disc so i figured might as well do it all now before i get married in a few months and dont have the dough
No i did not do that. I could not find any one with a lathe big enough to ft the axle in SO i counter sunk the aluminum rim so the axle sits flush.If a steel wheel is used no rim mods are required becuase they are much thinner than the aluminum one.The only sorta down side is that the axle must be removed to remove the wheel.But thats only 8 bolts extra ,so it is like a 6+8= 14 lug ....lol
Here is a pick of the install completed with the rims.I dont have any of the actual adaptor yet i will try to find one and get it posted.
