14bff ARB help
bp71k5
3/4 ton status
Knoxville, TN 37922
Does anyone here know how to separate the case halves of the rd114 ARB locker?
I've got a weird problem in that the holes for the ring gear are not quite lined up and the ring gear bolts will not go through the holes because of it. I'm thinking I may be able to loosen the halves a bit and retighten things down after lining up the bolt holes.
I only see two small countersunk screws that appear to hold the case halves together and I'd think there's be more.
