Ok, so I'm finally moving forward on this project and need some help.
I'm using weld on brackets for this and need to know which way I should push the caliper on the rods. Is A or B the correct position prior to welding?
I believe A to be correct as when the pads ware down the caliper will slide away from the disc and pull the outside pad to the disc.
