2 Questions here. I need to know what the name of the piece behind the E-Brake Adjuster arm is called. Its similar in size and is the one the cable actually connects to. The passenger side on this axle has one, but when we took the driver side apart the cable was just hanging inside the drum. I've been to Napa and got part# 80865, adjuster repair kit, but it only has the front arm. Also, I've got the new hardware kit for both brakes and its not in there either. They're telling me they can't find anything in the computer that references the rear lever.
Also, the carrier and ring gear have a lot of rust. It looked this axle got some water in it and than was left to sit for a couple of years. Lots of goopy rusty stuff came out of the tubes when we took it apart. I don't think the residual pitting on the housing, shafts, and tubes will be a big deal once its cleaned-up. But, I'm wondering if the carrier and R&P might need a little more attention.
Thanks in advance.
Thanks in advance.
Seriously.
