I took the Blazer for a test drive today to check out my t-case rebuild and let the u-bolts settle some more (I get more turns out of them every drive). Anyway, the rig seemed sluggish and when I got back I smelled the heat from one of the rear drums. Jacked it up and was unable to turn the passenger side by hand, but the driver's side had no drag at all. I always try to adjust the drums for just a hint of drag.
While I had it up, I tested the parking brake, and it worked great on driver's side but seemed to have minimal impact on passenger. I could still turn it by hand with the parking brake pedal maxed out.
Finally, the most concerning thing, I fired it up on the stands and put it in reverse. Max brake pedal pressure was unable to stop the wheels. They slowed almost to a stop, but not all the way. I'm pretty sure that indicates really weak braking back there, right?
I've bled probably a gallon of fluid through these brakes, but never felt really confident about it. The flow has always been minimal during bleeding. I've had assistants help and used a pressure bleeder. I'm not sure this is it, but maybe air in the lines would show this symptom? The parking brake stuff may be totally unrelated, or maybe I screwed up the rebuild? I pretty much replaced everything to do with the brakes... Could there be any prop valve or MC weirdness inhibiting the rear brakes? I replaced to MC with a 1-ton model, but everything else is the same.
