14BFF gear swap ability?
cybrfire
1 ton status
Iowa
Will the gears from a 1973-87 14BFF fit into the later model 14BFF with all the webbing and such on it?
Yes but the only difference between the older and newer ones is the pinion bearing which is smaller and larger on others. Not sure what the year split is to determine those though.
