14bff gears..
87 Blue Beast
York, Pa
so ive heard that 4.56 gears are the lowest you can fit into a 14bff housing, is this correct? if it is, what is the problem and what do you have to do make lower gears fit? is this a problem with d60's too?
14FF you can now get 5.38's and the D60 can go all the way to 7.17's
4.88's and 5.13's have been around for a long time and like mentioned above, you can get 5.38's now.
