Been lurking here for a little while and am finally making my first post
In January bought a 91 K5 with 170,000mi and 40,000mi on a reman 350 and rebuilt trany. 6"lift and 2" body lift. Bought a 83 3/4 ton chassis from a guy for $75 took the 14bff with a gov lok rear and hubs from the 10bolt front end and put them under my K5. While doing this I replaced all bearings and seals and put in 4.88 gears. while setting up the rear had a little over 20"lbs of preload while spinning the pinion bearing and a good pattern on the gears. New u Joints in all drive shafts and front axel and rebuilt the cv.
Took it for its firs test drive today. Nice and quiet while accelerating and maintaining speed, but has a noise while it coasts. the best way to describe it would be a long low pitched rattley duck quack. Removed rear drive shaft and noise goes away. Front runs nice and smooth.
Was reading about similar problems and had things listed such as pinion bearings and u joints as issues. I am hoping it isn't pinion bearing cause with drive shaft out I figured it would be in coast condition all the time. and don't know if it is u joints cause they are all new.
Help.
Help.
AHHHHHHH
I love it. I can s-o-o-o-o relate to this.
