14BFF pinion gear ?
85k5dsl
Maryland
I have currently have a 14bff with 4:10's in my truck and I'm working on installing a D60 front axle from a DRW truck. The 60 has 4:56's so I also took the 14bff rear. Seeing that both 4:10 and 4:56 gears have a 41 tooth ring gear can I just swap out the 4:10 10 tooth pinion for the 4:56 9 tooth pinion and be done ?
Thank
Mark
No, gear sets are lapped matched sets and cannot be swapped like that.
The gear contact would be way off and would severely compromise the strength and longevity of the gearset.
Why did you quote me? I told him it can't be done and that is a correct statement. :confused:
Thanks for the feedback. I just finished installing the 4:56's.
Mark
Sorry, I initially was just going to type "X2" as my response, quoting you. I decided to type something else and forgot that I was still quoting you. What you said is 100% correct.
