14BFF Small Parts
rcamacho
WA
I'm in need of an extra axle flange bolt and the aluminum gasket between the hub and flange. Any suggestions?
the axle flange bolts are regilar 1/2" grade 8's, id go to the junkyard for the gasket thing or just slap some RTV in there and call it good.
Finally got around to fixing the leaking flange. The po used RTV which would not hold. The local GM dealer had a replacement gasket for ~$4. Unfortunately it's a weird paper compound rather than aluminum so it's probably a single use item.
I got metal ones at my local parts house. Only use rtv on the trail.
Wes
I got the metal one at Auto Zone for $1.99 each. The paper ones will leak.
